Resolved! Viper26 power supply design
Hi, anyone tells me how to design a 24vdc to 15vdc buck converter using viper26ld?
I'm currently measuring the power loss of a 3 phase rectifier comprised of STTH3010W diodes. I have my preliminary results obtained by measuring the voltage drop and current through an individual diode on my oscilloscope. I'm just looking now to ve...
I am working on SPSB081 power management control IC. I need support in the following points:1. which revision of data sheet to be followed, because there are some discrepancies in register set(addresses) of revision 2 datasheet.2. for refreshing the ...
Posted on February 10, 2017 at 15:32Dear all, I need to know the range of the parameters (load capacitance, series resistance) allowed by the STPM32 IC.I didn't find these values neither on the datasheets nor on the applications. Can you help me?Tha...
need same or equivalent of shottkey diode ST MAKE BBG Z128 OR BBG Z616
(Note: I raised a support case about this, but it was closed, and requested that I ask in here). I wondered if there are any further details / anyone is aware of any issues with adding a capacitor from CS in (23) to ground (so in parallel across the ...
Hi, can anybody tell me what type of diode I see here?Marking is:VUE XGP 842Must be TVS for low voltage application (24 & 48 VDC)Thanks David
Where I can find the document of M41T0 device marking?
HI all,Has anyone come across their HS switch putting voltage back onto the input pin of this device which is at VCC level (28V for me) so this is then going back to my microcontroller and damaging it. In what scenario is this even possible?Here is m...
I have some EOL components with two different part numbers, but I believe they are the same. VND600SP13TR HSOP10 and VND600SP13TR SOP10. What is the difference between the HSOP10 and the SOP10?
