Power management
Input voltage to STPM34
Hello,I want to use the STPM34 board for the metrology of a voltage line with a fairly large voltage value (in the order of kV) since it is commanded to use this module for the metrology of all voltage domains .The problem that the nominal voltage of...
L6234 ESD
Can someone provide ESD (HBM & CDM) values for the above part
CHodd.1 by Associate
  • 1249 Views
L6235Q control motor mode
I use L6235Q to control the Maxon small DC brushless motor with Hall, and now I have the following issues:1. Can we achieve sinusoidal signal control of motor rotation. I want to control the motor to rotate forward for 3 turns and then reverse for an...
JIE by Associate
  • 1683 Views
LTSpice Model for ADP480120W3
I am performing a research at my university and hence need the LT Spice model of the ADP480120W3 power module. Please help.
ankush by Associate
  • 838 Views
