2005-09-28 10:42 PM
2011-05-17 1:18 AM
hi.
let's open an about st7mc page 146. last text line tells us :''Z event filter is also active in sensor mode.'' now the same an,but page 157, table 34 (Sensor/sensorless mode and D & Z event selection), last row, column ''Window and Event Filters'' : ''No filter in Sensor mode''. It is true for D event only, but for Z event we have Z event filter active and Z window filter disabled. Am i right?2011-05-17 1:18 AM
Hi.
I found one more error in this datasheet. page 164, second column, line 7: instead of ''MISR'' should be ''MIMR''. Regards.2011-05-17 1:18 AM
effectively there is an error in the ST7FMC datasheet at page 157 in table 34: the correct message must be ''No Z Window filter, only Z event filter is active in sensor mode''. Regards, Tanio2011-05-17 1:18 AM
Ciao Luter,
thanks for your recommendation. Best regards, TanioWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
