stm32f3xx_ll_opamp.h (STM32F3xx_DFP v2.1.0) bug
File: Arm/Packs/Keil/STM32F3xx_DFP/2.1.0/Drivers/STM32F3xx_HAL_Driver/Inc/stm32f3xx_ll_opamp.h
In this file, function LL_OPAMP_GetCalibrationSelection(), at lines 710-711:
  return (CalibrationSelection |
          ((OPAMP_CSR_TRIMOFFSETN) << (POSITION_VAL(OPAMP_CSR_TRIMOFFSETP) * (CalibrationSelection && OPAMP_CSR_CALSEL))));
The logical "&&" should be a bitwise "&".
ARM compiler v6 generates a warning for this, whereas v5 does not.
2 REPLIES 2
Imen GH
Hi @Steve Melnikoff​ ​,
Thank you for your feedbacks!
I will raise your reported case internally to take into consideration.
Imen
Note this version of the code is from the latest Keil ST pack. The version of the code in the GitHub repo has been rewritten to avoid this problem.
(My other recent bug report asks that the Keil pack be updated - but we've now switched to the GitHub version to avoid these issues.)
