2025-04-28 5:31 PM - last edited on 2025-04-29 1:39 AM by mƎALLEm
I'm trying to code the NUCLEO-H755ZI-Q in the Arduino IDE and it uploads but won't run.
I have the USB connected to USBPWR and the jumper connected to STLINK.
The code is written like this:
void setup() {
Serial.begin(115200);
while (!Serial);
Serial.println("NUCLEO-H755ZI-Q: Hello from M7 core!");
void loop() {
Serial.println("Looping...");
delay(1000);
The code was uploaded but nothing was output on the serial monitor.
Please let me know why and how to fix it.
Thank you.
*This post has been translated from Korean to comply with the ST Community guidelines.
2025-04-29 12:14 AM
I don't see nucleo-H755zi in the list of officially supported boards.
https://github.com/stm32duino/Arduino_Core_STM32#boards-available
2025-04-29 1:21 AM
Welcome to the forum.
Please see How to write your question to maximize your chances to find a solution; in particular How to insert source code.
The Arduino IDE should allow you to use the debugger - so have you used the debugger to see what's happening?
For support with STM32Duino, see: https://www.stm32duino.com/
For support with the Arduino IDE, see: https://forum.arduino.cc/c/development-tools/ide-2-x/93
2025-05-25 6:44 PM
Hi, i also use this board and if i am not wrong you will need to use STMCUBEIDE in order to setup and code the NUCLEO-H755ZI-Q this board have some advance setiing like dual core, DMA and many others that require the cube ide in order to use them
