2014-09-17 8:06 AM
hi when i add a cpp library to keil project,it shows this error:
its while i have no problem with c librariestnks2014-09-17 1:21 PM
Well, it clearly tells you to, ''check 'Options for Target - Utilities''' - so did you do that?
And the error is coming from FCARM - so have you checked the documentation for FCARM?We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
