2025-05-28 4:40 AM - last edited on 2025-05-29 1:18 AM by Andrew Neil
In TTN, it says my gateway is connected to other cluster.
I'm not able to change it to connected. What should I do?
2025-05-28 5:00 AM
Are you sure you have the correct ID for your actual gateway?
If you've just used a default, someone else has already registered that ...
2025-05-28 8:37 PM - edited 2025-05-28 8:52 PM
I have not used a default gateway ID . I have used the actual ID only. What should I do?
2025-05-29 1:05 AM
Where did you get that ID ?
