2019-07-24 5:20 AM
我使用STM32F407ZET6,仿真软件IAR,仿真器JLINK,在软件加载�?�全速�?行是没有问题的,但是一旦暂�?�就死机,软件报错退出。
2019-07-24 5:57 AM
"I use STM32F407ZET6, simulation software IAR, emulator JLINK, there is no problem running at full speed after the software is loaded, but once it pauses, it crashes and the software reports an error."
Ok so you're going to need to learn to use a debugger, and instrument your code, so you can understand what is happening and why it is failing.
