2004-03-22 1:41 AM
2004-03-16 11:04 PM
In the same Module in diff. lines the assembler takes a 8- and 16-Bit Addr. for the correct in ST7LITE2.asm specified Hardw.Register EECSR. Therefor a phase inconsistency occurs in asm2.
How can I solve this problem? regars Kurt2004-03-21 5:00 PM
How have you defined this register? Could you attach your mapping file and the file that is producing the error?
2004-03-21 10:25 PM
I could solve his problem. See my answer to my other asm-problem.
Just now I haven't found the correct proceeding to build an application of e.g. 15 source files, 1 common INIT file, 1 common constant file, 1 common RAM file. For Testing I copy all needed source files in 1 big source file with ST7LITE2.asm, RAM.asm and CONSTANT.asm as #INCLUDE. After testing I copy back the debugged source code of each module in the big source file to the assosiated source code module. If you have a better solution which really works I would appriciate to know how. KurtQuote:
On 2004-03-22 06:30, Jatin wrote: How have you defined this register? Could you attach your mapping file and the file that is producing the error?2004-03-22 1:41 AM
I am a little confused by your comments on multi source file projects.
As long as the required functions/memory is declared public in the asm file (. being the easiest method) and extern in the inc file you will have no problems. The only thing I would say is always compile your micro registers first. I generally use gmake and have attached a sample makefile I use. Regards sjo ________________ Attachments : isp.mak : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HzUy&d=%2Fa%2F0X0000000bTY%2FCQTRuK4bu_wYx5JTodNqpsv0kEW6Ms8njhS8Uue5Aok&asPdf=falseWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
