2014-06-12 12:15 PM
I am new to STM parts. the data sheet I have from ST on the 8 bit MCU does not have a detailed description of SFR's. So I need someone to post a link to the files because I have looked all over and found a bunch of stuff I can't use.
Also is there any example projects for basic stuff out there? I need to do something very basic and none of the documentation I have found explains how to do it. What I need to sart with is an interupt from a timer overflow so I can set up a 1msec flag for general state machine control. Thanks for any help! I am adding that if I break in the debugger and set the values it works. but using the following code is not setting the values. TIM4->ARR = 0x80; TIM4->PSCR= 0x07; TIM4->IER = 0x01; TIM4->CR1 |= 0x01;We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
