2020-03-20 8:16 AM
I am trying to programatically validate the tpm cert.
I extract the URL from tpm certificate http://secure.globalsign.com/stmtpmeccint01.crt.
Certificate:
Data:
Version: 3 (0x2)
Signature Algorithm: ecdsa-with-SHA256
Issuer:
commonName = STM TPM ECC Intermediate CA 01
organizationName = STMicroelectronics NV
countryName = CH
X509v3 Basic Constraints: critical
CA:FALSE
X509v3 Extended Key Usage:
2.23.133.8.1
X509v3 Key Usage: critical
Key Agreement
Authority Information Access:
CA Issuers - URI:http://secure.globalsign.com/stmtpmeccint01.crt
I get HTTP error 404 not found when i access the url.
2020-04-24 6:09 AM
Your extraction is correct http://secure.globalsign.com/stmtpmeccint01.crt is the is good url. HTTP error comes from probably temporary network issue. Could you try again ?
Best Regards,
Benoit
2020-04-24 7:27 AM
Your extraction is correct, http://secure.globalsign.com/stmtpmeccint01.crt is the good URL. Actually, link works, You met probably temporary network issue. Could you try again ?
Thank in advance,
Best Regards,
Benoit
