2014-01-17 10:41 AM
Hi, I would like to know if someone had been capable to use the complementary outputs of timer 1, I found an example in the standard peripheral library called
TIM1_ComplementarySignals_DeadTime_Break_LockI flashed it in the Discovery board, the normal OC outputs are OK but the complementary outputs doesn't work y have changed polarity and read the datasheet but I can't get it to work,Could you advise?Tnx #tim1-pwm-complementary-outputs2014-06-06 5:06 PM
Hello, Aaron.
Check the option byte OPT2, bit AFR5. You need to enable port B0 alternate function.Hope it helps. Good luck!We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
