2018-03-20 1:41 PM
Both pd5 and pd6 on 003k3 have same structure as on 003f3. So i feel its quite possible they can be used as adc's on 003k3. I didnt see any reference to that in datasheet neither on reference manual explicitly mentioning that.
2018-03-20 11:21 PM
chandel.abhishek
don't worry about your question; most likely someone else will have the same question, so I thank you for posting it!2018-03-21 12:46 AM
Tested said ports for ADC functionality and they worked fine as I was expecting.
2018-03-21 6:57 AM
I makes sense. the die is likely the same. ST just wanted to introduce some differentiation when there is none. I think we have seen a few data points like that.
2018-03-26 2:44 AM
I did tried to search for it in manual/datasheet as well as on web but could'nt find anything (maybe I didnt look good enough) so I thought to go ahead with actual testing and ports worked just fine with Analog inputs. so yeah PD3, PD5 and PD6 are indeed connected to adc module. though I cant comment on possible interference with existing port/pin features.
