2025-06-05 1:25 AM - last edited on 2025-06-05 2:10 AM by Peter BENSCH
Hi, everyone
This TDA2030A amplifier module use dual power supply ±12 Voltage
See attached image file
Thanks
2025-06-05 2:24 AM
Firstly, please note that the TDA2030A has been discontinued many, many years ago and has not been manufactured by STMicroelectronics since then.
Your photo shows an Asian product that uses the TDA2030A in single supply configuration.
/Peter
2025-06-05 1:30 AM
And your question is?
2025-06-05 1:53 AM
TDA2030A AMPLIFIER MODULE USE DUAL POWER SUPPLY
2025-06-05 1:55 AM
This board use dual power supply voltage
2025-06-05 2:04 AM
Ah, so you are asking if this board uses dual power supply, correct?
Looks a lot like the modules you can get for almost nothing on Aliexpress: TDA2030 Module Voeding TDA2030 Audioversterker Board Module TDA2030A 6-12V Enkel - AliExpress
These have a single-ended supply.
2025-06-05 2:07 AM
Thanks
2025-06-05 2:24 AM
/Peter
2025-06-05 3:13 AM
Ok
