2008-06-12 4:35 AM
2008-06-12 4:35 AM
ST7FLITE2, it's in halt most of the time to save poer. Interrupts once a sec, but if I try and change PB3 from output to input and back the thing crashes big time. I go...
PBOR=0x00; // outputs to floating PBDDR=0x07; //PB3 to input PBOR=0xFF; // pullups /push pull I put a bit of delay between each to allow the ports to settle and reverse the process to get back...I thing the micro is timing out or getting a spurious interrupt.. Any ideas. Del (the cat)We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
