2005-12-22 4:47 AM
STVD7 can't build project. Need a little help!
2005-12-13 4:10 AM
Hi.
I'm new in working with STVD7 (2.5.4). At the moment I try to build a project that comes as a sample by STVD7. I did only some few changes but I get every time the following erroer message: Starting ''build'' process: gmake -f BLDC_Cosmic.mak cxst 7 +modms -l +strict +split -i C:\_ST7\BLDC_Sless_Test\source -co C:\_ST7\BLDC_Sless_Test\object\Cosmic main.c process begin: CreateProcess((null), cxst 7 +modms -l +strict +split -i C:\_ST7\BLDC_Sless_Test\source -co C:\_ST7\BLDC_Sless_Test\object\Cosmic main.c, ...) failed. make (e=2): The system can not found the specified file. gmake.exe *** [main.o] Error 2 Build failed. I tried a lot to find the failure, modifiy makefile and so on but nothing helped. Is someone here who is familiar with this problem and can help me. Thanks, RoB.2005-12-13 6:27 PM
Hallo.
Why don't u use last release of STDV? It is very convenient. U will get rid of most of your problems.2005-12-22 4:47 AM
Hi Luther!
Thanks for your advise. It worked well. Now I can compile my projects. It was a weird failure. By, RoB :-]We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
