2007-01-29 6:46 AM
Stuck in Startup Code (STR912FW44)
2011-05-17 12:35 AM
I am starting to get into uC programming with the Keil MCBSTR9. First step was to rewrite their example Blinky using the ST Software Lib. Compiling, linking worked and so did uploading. But nothing is happening on the board. So I tried to debug. For some reasons the debugger gets stuck in the Startup file... Any hints? Help appreciated. Cheers Nik2011-05-17 12:35 AM
thanks for the reply. Must have been some kind of a bug in the Keil software or in my setup (I am running the uVision in VMWare under Linux). Now it is working. Cheers NikWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
