2008-06-27 1:05 AM
STR912FAW44 Revision H and U-LINK issue
2011-05-17 12:53 AM
Hi Guys,
We have started using a hardware design with STR912FAW44 (Revision H) CPU. We are experiencing problems to use MDK-ARM of Keil and U-lINK as a JTAG for debugging. The following message occurs: Memory missmatch Address: 0x00008000 Value: =0x04 Expected: = 0x38 No problems to erase / program / verify. Are anyone using already this revision H and have the same issue? Thanks a lot in advance, Boomer2011-05-17 12:53 AM
Yep, I was able to overcome it.
Just uncheck “Verify Code Download�? option. in Debug -> Settings.. Another way, suggested by ST, is to uncheck “Use Reset at Startup�?. Both work.2011-05-17 12:53 AM
try to download your code using the download button(Flash-> Download) then start the debug session(Debug-> satrt\stop debug session)
2011-05-17 12:53 AM
I am having the same problem, has anyone found a solution for this? Thanks, JuliusWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
