2005-06-30 11:35 PM
2005-06-21 3:18 AM
I'm looking for info about using CPUID to safely identify the STPC Consumer II CPU.
The routine I'm using now does not work, the STPC is identified as an INTEL 486 CPU. This code was working with the STPC Consumer. As far as I see this information is missing from both the data sheet and the programming manual. Thank you for your help.2005-06-30 11:35 PM
The STPC consumerII is not an Intel 486 and you can see this information in the datasheet in Description section 'page1' that the STPC Consumer-II integrates a standard 5th
generation x86 core.....We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
