How to support hard disk on a Consumer-II board in WinCE 4.2?
wangmowei
Associate II
Posted on June 30, 2005 at 11:03
2 REPLIES 2
wangmowei
Associate II
Posted on June 28, 2005 at 08:32
Does you know how to support hard disk on a Consumer-II board in WinCE 4.2? And how to use hive-based registry?
Any hint will be helpful. Thanks!
kaouther
Associate II
To use the Hard disk with wince, you have to add a new Environment variable for the storage device :
1- with the platform Builder , select the ''Platform'' from the menu and then the ''Platform setting''.
Attached, a screen shot on how to add this value.
2- Then, you have to rebuild your platform and make your image.
Now, your hard disk should work.
________________
Attachments :
Platform-setting.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006Htss&d=%2Fa%2F0X0000000aYK%2FJjlQYW_CbcYkLYywqb_UfcwZDqXVcbCwcRFgmcMYsRA&asPdf=false
