2010-10-28 1:34 AM
STM8S105 Interrupt Execution Time (using Raisonance Ride 7)
2011-05-17 6:11 AM
2011-05-17 6:11 AM
Hi lowpowermcu,
Actually, i'm testing on a pre-designed pcb circuit, so my timer 1 does not connect to any LEDs, only timer3 does. That's why i'm using timer3.
Understands that setting CCR to the ratio of the ARR can get the desired outcome... As i need to show that I can use PWM mode to make the LED glow and off.
Currently I manage to get the effect on and going.
Thanks a lot.
Hi toh.seng_huat, why you don't use TIM1 in PWM mode ? You can run timer counter in 1ms (as example) and channel 1 in pwm: ARR = 3000 and CCR1 = 2000 and you will get your signal without caring about it in software. Your CPU will be loaded-off. MCU LüfetrWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
