2025-11-15 4:20 AM
Hallo.
I want to measure a pwm-signal (period 20ms, Puls 1,5ms +- 0,5ms)
I made a assembler program to capture the positive and negative transitions of the signal according the RefManual RM0016, Rev14, page 170.
I tried various versions but the negative transition is never captured, TIM1_CCR2 contains the period value or 0. TIM1CCR1 contains the period value as expected.
where is my fault ?
Please support.
Sincerely
Christian
stm8/
; TITLE: fsm1.asm
; AUTHOR: SCh, 25 10 01 SCh
; Copyright 2015- , Dipl.-Ing.Christian Schmid, A-4973 St.Martin
; DESCRIPTION: Funkschaltmodul
; 0.10, 24 07 24 SCh, erster Test ?
; 0.13, 25 11 11 SCh,
; 0.14, 25 11 12 SCh,
;Macros
#include "mapping.inc"
#include "STM8S105x.asm" ;<- verwendeter uC K4
;Konstante (bytes)
BYTES
FREQ EQU 2 ;=fmaster=fosz/CLK_CKDIVR
NSER EQU 8 ;Anzahl bytes seriell aus
MU EQU 162 ;Schaltwert unten
MO EQU 213 ;Schaltwert oben
MM EQU 187 ;Wert Mitte
;Variable
segment 'ram0'
BYTES
v DS.B 1 ;Var zeiten
v1 DS.B 1 ;
eing DS.B 1 ;Merker: 0:Eingang
segment 'ram1'
WORDS
buf DS.B 8 ;Buffer i2c
segment 'eeprom'
WORDS
eeprom DS.B 64
;Programm
segment 'rom'
WORDS
;Konstante (words)
FAK1 EQU 8700
;Texte xxxxxxxxxxxxxxxx
STRING "Version014 fsm1" ;
;Tabelle
start:
;initialize int. Oszillator
mov CLK_CKDIVR,#%00011000 ;set internal clock 2MHz
;initialize SP
ldw X,#stack_end
ldw SP,X
#ifdef RAM0
;clear RAM0
ram0_start.b EQU $ram0_segment_start
ram0_end.b EQU $ram0_segment_end
ldw X,#ram0_start
clear_ram0
clr (X)
incw X
cpw X,#ram0_end
jrule clear_ram0
#endif
#ifdef RAM1
;clear RAM1
ram1_start.w EQU $ram1_segment_start
ram1_end.w EQU $ram1_segment_end
ldw X,#ram1_start
clear_ram1
clr (X)
incw X
cpw X,#ram1_end
jrule clear_ram1
#endif
;clear stack
stack_start.w EQU $stack_segment_start
stack_end.w EQU $stack_segment_end
ldw X,#stack_start
clear_stack
clr (X)
incw X
cpw X,#stack_end
jrule clear_stack
;STM8S105C6T6 48pin LQFP48 (Pin v=vorhanden, nc=nicht vorhanden)
;config io: dd:0=in,1=out, cr1:0=fl/od,1=wpu/pp, cr2:0=noint/slow,1=int/fast
;Port A
mov PA_ODR,#%00000000 ;0:nc 1v:Oszin
mov PA_DDR,#%01101000 ;2v:Oszout 3v:pp
mov PA_CR1,#%01111110 ;4v:in pu 5v:pp
mov PA_CR2,#%00000000 ;6v:pp 7:nc
;Port B
mov PB_ODR,#%00110000 ;0v:frei 1v:frei
mov PB_DDR,#%00010000 ;2v:frei 3v:frei
mov PB_CR1,#%11001111 ;4v:SCL od 5v:SDA in fl
mov PB_CR2,#%00000000 ;6v:frei 7v:frei
;Port C
mov PC_ODR,#%00000000 ;0:nc 1v:TIM1ch1 in fl
mov PC_DDR,#%00000000 ;2v:TIM1ch2 infl ? 3v:frei
mov PC_CR1,#%11111000 ;4v:frei 5v:frei
mov PC_CR2,#%00000000 ;6v:frei 7v:frei
;Port D
mov PD_ODR,#%00000000 ;0v:pp LED 1v:SWIM, in fl
mov PD_DDR,#%00100001 ;2v:frei 3v:frei
mov PD_CR1,#%10111101 ;4v:frei 5v:TX pp
mov PD_CR2,#%00000000 ;6v:RX,in fl 7v:frei
;Port E
mov PE_ODR,#%00000000 ;0v:frei 1v:frei
mov PE_DDR,#%00000000 ;2v:frei 3v:frei
mov PE_CR1,#%01101001 ;4:nc 5v:frei
mov PE_CR2,#%00000000 ;6v:frei 7v:frei
;Port F
mov PF_ODR,#%00000000 ;0:nc 1:nc
mov PF_DDR,#%00000000 ;2:nc 3:nc
mov PF_CR1,#%00000000 ;4:nc 5:nc
mov PF_CR2,#%00000000 ;6:nc 7:nc
;Port G
mov PG_ODR,#%00000000 ;0v:frei 1v:frei
mov PG_DDR,#%00000000 ;2:nc 3:nc
mov PG_CR1,#%00000011 ;4:nc 5:nc
mov PG_CR2,#%00000000 ;6:nc 7:nc
;TIM1
mov TIM1_PSCRH,#%00000000 ;
mov TIM1_PSCRL,#%00001111 ; :16(4)=8usec pro Stufe
mov TIM1_CCMR1,#%00000001 ;ch 1, Periode
mov TIM2_CCER1,#%00100000 ;4:en ch2, 0:en ch1
mov TIM1_CCMR2,#%00000010 ;ch 2, Duty
mov TIM2_CCER2,#%00000000 ;4:en ch4, 0:en ch3
mov TIM1_CCMR3,#%00000000 ;ch 3,
mov TIM1_CCMR4,#%00000000 ;ch 4,
mov TIM1_SMCR,#%01010100 ;source
; mov TIM1_EGR,#%00000110 ;Ereignis
mov TIM1_IER,#%00000110 ;Interrupt enable
; bset TIM1_CR1,#0 ;enable counter TIM1
;TIM2
;SPI
;ADC
;UART seriell
; mov UART2_BRR2,#$01 ;
; mov UART2_BRR1,#$1a ;19200 Bd f r 8Mhz
mov UART2_BRR2,#$08 ;
mov UART2_BRR1,#$06 ;19200 Bd f r 2MHz
mov UART2_CR2,#%00001000 ;tx enable
;usermain
clr eing
mov {buf+0},#0
mov {buf+1},#0
mov {buf+2},#0
mov {buf+3},#0
mov {buf+4},#0 ;TEST
mov {buf+5},#%11100111 ;TEST E7
mov {buf+6},#0
mov {buf+7},#0
bset TIM1_CCER1,#0 ;enable capture 1
bset TIM1_CCER1,#4 ;enable capture 2
clr TIM1_SR1
clr TIM1_SR2
rim ;enable all interrupts
; main program loop
schleife:
call t20
call t20
call t20
ld A,{buf+3}
cp A,#MO
jrnc hp_2 ;>=
cp A,#MU
jrc hp_3 ;<
bres PA_ODR,#5
bres PA_ODR,#6
jp hp_9
hp_2 bset PA_ODR,#6
bres PA_ODR,#5
jp hp_9
hp_3 bres PA_ODR,#6
bset PA_ODR,#5
hp_9 bcpl PD_ODR,#0 ;Led blinkt
call ser_out
jp schleife ;5ms+serout
;UP
ser_out:
clrw X
wait_txe btjf UART2_SR,#7,wait_txe ;warte bis TXE=1
ld A,(buf,X)
ld UART2_DR,A
incw X
cpw X,#NSER
jrne wait_txe
ret
t20 mov v,#{14 mult FREQ} ;20ms
zeit1 mov v1,#236
zeit2 nop
nop
nop
dec v1
jrne zeit2
dec v
jrne zeit1
ret
;externe SUB
;Interrupt Handler
interrupt NonHandledInterrupt
NonHandledInterrupt
iret
interrupt tim1cap
tim1cap
ld A,TIM1_SR1
ld {buf+4},A
and A,#%00000010
jreq tm1c_14 ;nur lesen wenn capture2
mov {buf+0},TIM1_CCR1H
mov {buf+1},TIM1_CCR1L ;lese Periode
bcpl PA_ODR,#3 ;Ausgang blinkt
tm1c_14 ld A,{buf+4}
and A,#%00000100
jreq tm1c_15
mov {buf+2},TIM1_CCR2H
mov {buf+3},TIM1_CCR2L ;lese Duty
clr TIM1_SR1
jp tm1c_19
tm1c_15 clr TIM1_SR1 ;;
tm1c_19 mov {buf+6},TIM1_SR2
clr TIM1_SR2
iret
segment 'vectit'
dc.l {$82000000+start} ; reset
dc.l {$82000000+NonHandledInterrupt} ; trap
dc.l {$82000000+NonHandledInterrupt} ; irq0
dc.l {$82000000+NonHandledInterrupt} ; irq1
dc.l {$82000000+NonHandledInterrupt} ; irq2
dc.l {$82000000+NonHandledInterrupt} ; irq3
dc.l {$82000000+NonHandledInterrupt} ; irq4
dc.l {$82000000+NonHandledInterrupt} ; irq5
dc.l {$82000000+NonHandledInterrupt} ; irq6
dc.l {$82000000+NonHandledInterrupt} ; irq7
dc.l {$82000000+NonHandledInterrupt} ; irq8
dc.l {$82000000+NonHandledInterrupt} ; irq9
dc.l {$82000000+NonHandledInterrupt} ; irq10
dc.l {$82000000+NonHandledInterrupt} ; irq11
dc.l {$82000000+tim1cap} ; irq12 TIM1 CC
dc.l {$82000000+NonHandledInterrupt} ; irq13
dc.l {$82000000+NonHandledInterrupt} ; irq14
dc.l {$82000000+NonHandledInterrupt} ; irq15
dc.l {$82000000+NonHandledInterrupt} ; irq16
dc.l {$82000000+NonHandledInterrupt} ; irq17
dc.l {$82000000+NonHandledInterrupt} ; irq18
dc.l {$82000000+NonHandledInterrupt} ; irq19
dc.l {$82000000+NonHandledInterrupt} ; irq20
dc.l {$82000000+NonHandledInterrupt} ; irq21
dc.l {$82000000+NonHandledInterrupt} ; irq22
dc.l {$82000000+NonHandledInterrupt} ; irq23
dc.l {$82000000+NonHandledInterrupt} ; irq24
dc.l {$82000000+NonHandledInterrupt} ; irq25
dc.l {$82000000+NonHandledInterrupt} ; irq26
dc.l {$82000000+NonHandledInterrupt} ; irq27
dc.l {$82000000+NonHandledInterrupt} ; irq28
dc.l {$82000000+NonHandledInterrupt} ; irq29
end ;dahinter eine leere Zeile !
2025-12-20 4:43 AM
Hello!
I sent the question to the ST support and Mr. Novak found my mistake.
I wrote TIM2_CCER1 instead TIM1_CCER1.
He also gave me a simpler solution for my task.
Thanks to all and especially to Mr. Novak.
Christian
sample:
stm8/
#include "STM8S105C_S.inc"
segment 'ram0'
BYTES
cap1h DS.B 1
cap1l DS.B 1
cap2h DS.B 1
cap2l DS.B 1
segment 'rom'
main.l
; initialize SP
ldw X,#stack_end
ldw SP,X
#ifdef RAM0
; clear RAM0
ldw X,#ram0_start
clear_ram0.l
clr (X)
incw X
cpw X,#ram0_end
jrule clear_ram0
#endif
#ifdef RAM1
; clear RAM1
ldw X,#ram1_start
clear_ram1.l
clr (X)
incw X
cpw X,#ram1_end
jrule clear_ram1
#endif
; clear stack
ldw X,#stack_start
clear_stack.l
clr (X)
incw X
cpw X,#stack_end
jrule clear_stack
;whole
mov PC_CR1, #{1 shl 1};PC1 pull-up; input should be default
mov TIM1_PSCRL, #{16-1} ;
mov TIM1_CCMR1, #$1 ;TIM1_CCMR_CCxS
mov TIM1_CCMR2, #$2 ;TIM1_CCMR_CCxS
mov TIM1_SMCR, #$54 ;slave mode reset C2
mov TIM1_CCER1, #$31 ;enable captures differing in polarity
mov TIM1_CR1, #$1 ; CEN
mov TIM1_IER, #{1 shl 1};CC1
rim
infinite_loop.l
jra infinite_loop
TIM1_cc_irr.l
clr TIM1_SR1
MOV cap1h, TIM1_CCR1H
MOV cap1l, TIM1_CCR1L
MOV cap2h, TIM1_CCR2H
MOV cap2l, TIM1_CCR2L
clr TIM1_CCR1H
clr TIM1_CCR1L
clr TIM1_CCR2H
clr TIM1_CCR2L
iret
NonHandledInterrupt.l
iret
segment 'vectit'
dc.l {$82000000+main} ; reset
dc.l {$82000000+TIM1_cc_irr} ; irq12
end
2025-11-17 7:33 AM
I don't' know which assembler you are using, but I think you are using a wrong instruction.
; ld {buf+4},A
; should be
ld buf+4,A
tm1c_14
; ld A,{buf+4}
; should be
ld A,buf+4
2025-11-19 2:47 AM
Hello AA1
I use this term for many years and after build the .lst file shows that it works correct.
I use the STVD toolchain V4.3.12
My question is: Are the config bytes for TIM1 complete and correct set ?
Must the CC1G and CC2G bits set in EGR Register ?
Is the interrupt routine correct ?
For me I guess that the negative transition sets the CC2IF bit but does not write the CCR2 bytes ???
CCR1 contains the correct value (9C2 hex = 2498 x 8us = 19,984 ms (20ms))
CCR2 contains the same value ??? even if I set CC1IE=0
2025-12-20 4:43 AM
Hello!
Christian
sample:
stm8/
segment 'ram0'
BYTES
cap1h DS.B 1
cap1l DS.B 1
cap2h DS.B 1
cap2l DS.B 1
segment 'rom'
main.l
; initialize SP
ldw X,#stack_end
ldw SP,X
#ifdef RAM0
; clear RAM0
ldw X,#ram0_start
clear_ram0.l
clr (X)
incw X
cpw X,#ram0_end
jrule clear_ram0
#endif
#ifdef RAM1
; clear RAM1
ldw X,#ram1_start
clear_ram1.l
clr (X)
incw X
cpw X,#ram1_end
jrule clear_ram1
#endif
; clear stack
ldw X,#stack_start
clear_stack.l
clr (X)
incw X
cpw X,#stack_end
jrule clear_stack
;whole
rim
infinite_loop.l
jra infinite_loop
TIM1_cc_irr.l
clr TIM1_SR1
clr TIM1_CCR1H
clr TIM1_CCR1L
clr TIM1_CCR2H
clr TIM1_CCR2L
iret
iret
segment 'vectit'
end
