2006-02-16 3:45 PM
2006-01-30 4:06 PM
Hello,I am Pop from Japan.
Would you please give me your advice? We have ST7 STICK and EPB(ST7MDT10-SB/123). Now, We are trying to setup ST7 STICK and EPB with PC for programming ST7 microcomputer. However,We may broken ST7 STICK during try to setup. Because we measured ST7 STICK `s test pin2-4 voltage value. Our measure result was that pin2(external power voltage )value is 10.7V and pin3(Vcc voltage) value is 2.3V. The STICK user manual write that pin2 value should be 13.5[V] to 23[V] and pin 3 value is regulated at 5[V]. We think that our pin value has problem. What do you think ? Also , What should we do for repair it By the way , We have some questions about ST7 STICK and EPB. Would you please give us answer ? ・How should we connect W1 Jumper of STICK and EPB? We don`t understand about them…. Our microcomputar supply voltage VDD is 5[V]. So, Should we connect W1 Jumper at 5V position ? , But Can we connect W1 Jumper at VDD potition too ? Would you please tell us 5V potition and VDD potition differences or relation ? ・Is there order of connect when we connect STICK and EPB to PC ? If there is order of connect ,What kind of order should we connect them? ・What kind of situation STICK and EPB broken ? ・If test pin become electric short , Are STICK and EPB destroyed ? ・If we suddenly disconnect AC/DC power supply keep on connect pararell cable to PC, Is it problem?  That`s all. Thank you for your reply. :-[ [ This message was edited by: Pop on 02-02-2006 09:25 ]2006-02-16 3:45 PM
Dear Mr Laurent
Thank you so much for your advice and kindness !!. I am so glad !! Now , we are trying to program again. We will contact you later if we have any further questions. Thank you so much again. Pop from JapanWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
