2004-10-07 3:14 AM
2004-10-06 3:28 AM
I have own build Stick programmer without High Voltage Programming Power Circuits. Programmer works good with ST7Lite (SX/0X/1X/2X)Family. But i have problem with PProgrammer RESET signal.
Programmer RESET signal is high when programing and it is ok, but after programming Reset signal is LOW so I must unplug ICP socket to start MCU.2004-10-07 3:14 AM
If its own build programmer, Put the reset signal of stick in input state so that it does not keep low. Keeping Low, for sure will keep the micro in reset.
