2023-08-17 12:00 AM
We are designing a led light with intrusion and occupancy feature. we found that STHS34PF80 will suit this application but still we have some doubts about sensitivity with out changing the default gain setting.
1.Do the sensitivity and performance gets affected if we place STHS34PF80 very close to LEDs that are mounted in same PCB?
2.Does the range and sensitivity get affected if we place STHS34PF80 inside the LED diffuser housing?
2a. If so what will be percentage of reduction in sensitivity and range from using a transparent housing?
Please clarify the above doubts and share if you have any application case study results for STHS34PF80.
