2003-10-13 11:55 AM
ST72C254G2 High speed resonator start up
2003-09-28 9:42 PM
My 16MHZ Crystal does not always start:
68pf load caps, no load caps, no difference!. When clock filter is enabled and ST7 is running on back up clock, is it possible to kick start HSR circuit with software method or do I have to keep cycling power until it starts!!.. Eternal thanks to anyone can help.2003-10-13 11:55 AM
Hi Deedub
I used to use a 2254 with a 16MHz crystal. My circuit used 33pf caps. It is always worth double checking your option byte settings. BMWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
