ST72621 PWM Mode......help
tuswu
Associate II
Posted on April 14, 2003 at 13:37
5 REPLIES 5
tuswu
Associate II
Posted on April 14, 2003 at 05:29
Dear all:
i can't get the wave form PWM1(PB.7)
My_Init()
SetBit (PBDDR ,7); //PB.7 --->output
PWMCR = 0x20; // PWM1 (PB7) is selected
ARTCSR = 0x78; // CPU clock, 62.5kHz, counter enabled
PWMDCR1 = 0x00;
something is woring?? help me please.......!!
florent2399
Associate II
Posted on April 14, 2003 at 07:14
Are you sure of the output IO? On my datasheet, I see the PWM output located from PB0 to PB3. By the way, you don't need to configure the IO in output mode, as the peripheral itself configures the IO in the right state.
Rgds
Florent
florent2399
Associate II
Posted on April 14, 2003 at 07:26
Sorry, I thought you were speaking about the ST72321 MCU...PB7 IO might be OK!
Rgds
Florent
florent2399
Associate II
Posted on April 14, 2003 at 07:55
I think that the PWMDCR value is not OK. It has to be greater than ARTARR, moreover greater than 0x00. Please check ARTARR & PWMDCR values....
Rgds
Florent
tuswu
Associate II
Hi Florent....
i found the bug,
PWMCR register does not mapping address correct in the .map file
thanks for your help....
