2006-01-26 8:35 PM
2006-01-25 12:30 AM
Thanks a lot for your answer, I'm going to try this tonight or tomorrow, I'll tell you how it worked. Philippe :D2006-01-26 2:33 AM
Quote:
@eeprom unsigned short tab[4]; the compiler shows this error message .... works fine here... I also tried using the array and the code generated looks correct; maybe you can try just adding that line (plus the line in the linker file) in one of the examples provided and work from there. Regards, Luca2006-01-26 8:35 PM
Luca,
you are completely right, it is working, I don't know what I was doing before... :-W THank you again ;)We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
