2004-09-29 6:00 PM
2004-09-19 6:34 PM
I want to use lite0x MCU A/D converter with amp enable. Can I input the
signal larger than 250mv? BR, mcuinterest2004-09-29 6:00 PM
The Amp works in linear mode upto 250mV as mentioned in specs. Above that, you many use but only on your risk, the result may not be linear.
