2006-02-22 5:23 AM
2005-09-16 2:50 PM
I am trying to reverse engineer an existing ST6 application. I have the .hex file but no source files. Are there any free or cheap tools that can decode the .hex file and generate the assembly instructions?
2005-09-18 9:43 PM
I wrote a plugin for IDA (http://www.datarescue.com), it is available at
other solutions include using the ceibo kit. its been a while since i have ventured down the st6 route. Regards sjo2005-09-21 9:13 AM
I took a quick look at the plug in files that you refered me to, but I don't know how to use a plugin. Does IDA Pro have a simple mechanism for activating and using the a group of files such as these?
Thanks for your help in advance. Gary2005-09-21 11:40 PM
Just place the plugin in the ida directory and it will be found.
Regards sjo2006-02-22 5:23 AM
Hi there
I was reading this forum and I found this issue, and I am now in the same problem. Could you tell me, how about decompiling the hex file, and if was successful. I’m trying to do the same thing but I have problems. please send message tomailto:curuchupa@hotmail.com
RegardsQuote:
On 17-09-2005 at 03:20, Anonymous wrote: I am trying to reverse engineer an existing ST6 application. I have the .hex file but no source files. Are there any free or cheap tools that can decode the .hex file and generate the assembly instructions?We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
