2008-04-16 8:33 AM
2011-05-17 12:52 AM
I am not able to persuade my RTC to generate periodic interrupts more frequent than 2Hz (that works just fine). In theory, the device should support 2, 16, 128 and 1024 Hz. Have you encountered this problem? I am currently running my program under a simulator (still didn't try the target).2011-05-17 12:52 AM
Hi Michael,
Have you seen the RTC Example2 delivered with STR9 software library available on ST web site? It aims to configure the RTC for generating a 1024Hz periodic interrupt. Regards, Eris.2011-05-17 12:52 AM
eris,
thanks for your reply. I have a MCBSTR9 and it seems that the RTC is functioning fine using Keil's simulator, but not when the program is placed on the target! I will ask Keil too, of course...We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
