2022-10-18 2:05 AM
hello sir
i use the ST visual development program
and tryed to give in that assembler instruction " int $040200"
but the assembler does not reconise that, altough its in that way its mentioned in the programming manual
also, can you inform me if "05" and "75" witch is the valuable instruction?
many thanks
marc debruyne
2022-10-20 5:34 AM
Dupe https://community.st.com/s/question/0D53W00001siX7USAU/hello-siri-use-the-st-development-program
Forums can be like empty rooms, if you don't get an answer, don't just repeat the question, add detail, think of ways of presenting things, and where other use cases and examples might be found, or generated. There's usually more than one way to approach things, and tools chains tend to create a circle. ie assemblers, compilers, linkers, debuggers, disassemblers. The data and technical manuals for the parts should get you instruction codings at a machine level.
If you have a formal business relationship with ST, talk to the FAE assigned to your account, or your other contacts.
