2006-06-13 1:20 AM
2006-06-13 12:34 AM
Hi!
I'd like to know if I could use the T1_OCMPB pin (1.6) as an output PWM pin instead of the T1_OCMPA pin? I didn't manage to get it toggling. Thanks2006-06-13 1:20 AM
I don't think you can use OCMPB pin. Datasheet said only OCMPA pin for output PWM : it's certainly due to implementation of timer.
If you need absolutely use OCMPB pin with a PWM signal, you can create this signal using 2 output compare Register and interrupt !We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
