2005-06-07 3:08 AM
Programming - Pl's help and try to support
2005-06-01 2:40 AM
Hello
with SoftecMicro Gang Progarmmer MP8011A and now i understand that it always erase default by manafacturer RC calibration values and i need to re-calibrate them BUT when i am using the ICP Indart one by one everything is working fine . Pl's advice if you know about other vendor of Gang programmer that can solve my problem . Thanks Amir Sherman2005-06-07 3:08 AM
Hi Amir,
As InDart is preventing the erase of the calibration option byte there isno reason why DataBlaze could not do the same. You should ask Softec support to help you resolve your problem: support@softecmicro.com Best regards, AlainWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
