2005-10-11 4:45 AM
Problem during setup under Win XP sp2
2005-09-27 9:27 PM
hi,
I'have installed the ST7 toolkit under winxp with sp2. After the software install, it ask to me that haven't found the parallel driver, and next the system crash (with blue screen) and restart! :-W I'm not able to use the st7 software!! :-[ please help me! :o tnx! :-]2005-09-28 6:50 AM
I had the same problem first, but then I manually removed parstm.sys from c:\windows\system32\drivers and reinstalled the tool-kit. The installation then completes without crash and the tool-kit worked ok!
/bood2005-09-28 9:22 PM
first of all thanks for your response!
i've tried this solution, but doesn't work for me. I receive blue screen error BAD_POOL_CALLER :-[2005-09-28 11:32 PM
I've solved the problem removing an additional Serial/Parallel card that I've installed on this machine... thanks
2005-10-11 4:45 AM
Hy,
I use WXP Home SP2 on notebook but I have'nt Your problem. Is the parallel port used fro EMU tools? I use EMU 3 trhouth LAN without problem! ByeWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
