2004-05-04 5:30 AM
2004-04-30 3:30 AM
I have a pb with ST10Flasher. I want to download a program into an external flash (AM29F400) with the ST10 Flasher. What are the directives to do that.
Thanks and best Regards for your answer.2004-04-30 3:59 AM
It is not possible to use ST10Flasher for programming the AM29F
(You will find in attachment a document dealing with how to use the ST10Flasher in general) ________________ Attachments : ST10Flasher_Usermanual.doc : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0OZ&d=%2Fa%2F0X0000000bYQ%2FCQiRfkpTytfeIBw48PXho6zIu9M4GPOFgBDTKChNDWY&asPdf=false2004-05-02 11:47 PM
Thank you for your answer but if you want you can read the doc attached in this post and you can see that it's possible to program an external flash with st10fasher
2004-05-03 12:47 AM
Please, can you read the doc attached to this post
Regards. ________________ Attachments : ST10FlasherDLL.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I005&d=%2Fa%2F0X0000000bYP%2FCk0L3j7cNMbqgGDK8nkFLHuti_C9rGte5SJ.qW_y6rk&asPdf=falseWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
