Our latest PCB uses FERD40U45CT (Diode) but I have been notified that this is now obsolete. How long will this product be avalable? Do I need to urgently change my design or do I have plenty of time left for FERD40U45CT. I very much like this diode.
StephanB
Associate II
FERD40U45CT
Twin diode with very low voltage drop and has a small PCB foorprint.
1 ACCEPTED SOLUTION
Accepted Solutions
Last orders, Mid-August, 15-Week delivery.
In stock with DigiKey, order enough to get you to the point where you're comfortable bringing a new design into production.
I would not dally, only see 4K pcs in open stocks, would see it as a good arbitrage bet..
5 REPLIES 5
StephanB
Associate II
Thank you for the quick reply
Peter BENSCH
...or replace FERD40U45CT (TO-220AB) by FERD40U45CG (D2PAK), which is still active - well... yet.
/Peter
Thankyou yes I will use this instead.​
Peter BENSCH
Great!
When your question is answered, please mark this topic as answered by choosing Select as Best for the preferred answer, as also explained here. This will help other users find that answer faster.
Good luck!
/Peter
