Others: hardware and software
stm8s I2C Communication
Posted on February 12, 2016 at 14:20Hello,I want to use I2C Communication between two stm8s208cb MCUs. I use stm8s standard peripharel library. My code:Master:&sharpinclude ''stm8s.h''&sharpdefine I2C_SPEED 300000&sharpdefine OWN_ADDRESS    0xA0    ...
Reading a battery voltage on STM8S003F3
Posted on May 26, 2015 at 21:06Hey guys, I currently have an STM8S003F3 that is being powered by a battery. I want to be able to read the battery voltage, but am trying to reserve pins. I am trying to read the battery voltage off the Vdd pin and com...
cfleck by Associate II
  • 1718 Views
Push mechanism on stack fails during the function call when we select “Minimize code size (+compact)� option for optimization from the drop-down list in STVD with Cosmic compiler (4.4.2) for STM8
Posted on January 29, 2016 at 14:13Hello Everyone,I am facing some issue with cosmic compiler version 4.4.2 for STM8. I have seen following run time problems.Push mechanism on stack fails during the function call when we select “Minimize code size (...
code size of stm8
Posted on January 25, 2016 at 05:30Hi all,I am using IAR for stm8, but I do not know how to check code size(flash, RAM...), could you tell me where I can check?Thanks very much
np1 by Associate II
  • 1493 Views
STM8 Low powering
Posted on January 23, 2016 at 11:30Hello, I'm thinking about building a small device, like a badge or business card. I mainly want to display temperature on small alpha numeric display. Im looking for documentation about low powering in order to pow...
bobaston by Associate II
  • 1440 Views
