2003-08-26 2:01 AM
2003-08-14 1:57 AM
Hi all,
The datasheet rev2.0 for the ST7FLITE29 states that the clock selection Fltimer is not valid for PWM mode, does this also cover output compare mode? I ask this question because as soon as I select Fltimer my interrupt is never called, selecting either Fcpu or 32MHz all is ok. Selecting Fltimer was a valid option in the LITE9 devices and was very useful. Regards SJO2003-08-26 2:01 AM
You are right , it is a limitation.
