2015-06-09 1:44 AM
My customer wants to use A/LED5000 to design Automotive lighting
Vin=10~30V, Vout=30V/1.4~1.5A, LED=CREE XLamp XP-G2 series(Vf=3V, If?1.5A)It's possible to use Floating Boost circuit to design LED5000 on this project or any suggestion? James Chiu from Distributor, Yosun #led-driver2016-11-19 11:51 PM
Hi Team
Can you share any efficiency data for LED5000 based floating boost application.it will very appreciable if anyone can share the design documents with efficiency test result.Regards,Sandeep SindhuWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
