2004-12-10 3:34 AM
IAR workbench & JTAG for STR71x microcontrollers?
2004-10-28 7:03 PM
I am using IAR workbench and JTAG, for philips LPC21x microcontroller. But I am unable to use the same for ST microcontroller STR71x. Is there any additional settings required to use the same IAR workbench & JTAG for STR71x microcontrollers? Vinod2004-10-28 11:10 PM
Hi Ibtiss,
Thanks for ur response, I have tried with IAR Jlink, but the error message was ''invalid core ID'' pls give me more detais about changing the startup files and the map files. regards Vinod2004-10-29 3:50 AM
Hi Ibtiss,
I have tried to run the example as it is, and replaced lnkarm.xcl file with the given one. but while making the project I am getting the error as below ''Error[e6]: Program module ?RESET redeclared in file D:\Program files\IAR Systems\Embedded Workbench 3.2\ARM\LIB\dl4tpainl8.r79'' Regards VinodWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
