2003-08-06 9:34 PM
2011-05-17 2:55 AM
Hi.
we are trying to interface upsd 323X with Digital Temp sensor (LM75) I2C based. we have gone through the programmer's guide for I2C.We would like to know if any example codes are available for the same in assembly language. Thanking you, Purvi2011-05-17 2:55 AM
hi,
if you are using keil compiler you can see the assembler code generated by the C code in the debugger with the disassembly window. totof.We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
