2003-09-22 11:01 AM
2011-05-17 2:54 AM
1. After setting bits 6&7 of P3SFS (to enable I2C fn on these pins) and setting the CLK freq bits in S2CON, Write slave address data to S2DAT, and set STA.
2. Yes, this is legal. 3. No, just write a dummy byte, and go to step 1 4. You can clear ENI after all I2C transactions are complete 5. The slave will send its last ACK after the final data byte is received, but before the STOP condition.2011-05-17 2:54 AM
2011-05-17 2:54 AM
2011-05-17 2:54 AM
Yes... it seems there are no timing limitation into I2C protocol between one byte and the next .
[ This message was edited by: TheVice on 22-09-2003 23:40 ]We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
