2019-04-03 7:41 PM
----------- Project ild004v2 - STM8 Cosmic - Configuration Debug -------------
Compiling watchdog.c...
cxstm8 +modsl0 +debug -pxp -no -pp -l -i"x:\bu_thyristor_triac_rectifier\04_ase_thyristor_triac\promotion tools\digital dimmer with viper_steval-ild004v2\05_software\steval-ild004v2 software v1.0\steval-ild004v2 software v1.0\ild004v2" -i"C:\Program Files\COSMIC\FSE_Compilers\CXSTM8\Hstm8" -clDebug\ -coDebug\ watchdog.c
watchdog.c:
Compiling timer_config.c...
cxstm8 +modsl0 +debug -pxp -no -pp -l -i"x:\bu_thyristor_triac_rectifier\04_ase_thyristor_triac\promotion tools\digital dimmer with viper_steval-ild004v2\05_software\steval-ild004v2 software v1.0\steval-ild004v2 software v1.0\ild004v2" -i"C:\Program Files\COSMIC\FSE_Compilers\CXSTM8\Hstm8" -clDebug\ -coDebug\ timer_config.c
timer_config.c:
Compiling stm8_interrupt_vector.c...
cxstm8 +modsl0 +debug -pxp -no -pp -l -i"x:\bu_thyristor_triac_rectifier\04_ase_thyristor_triac\promotion tools\digital dimmer with viper_steval-ild004v2\05_software\steval-ild004v2 software v1.0\steval-ild004v2 software v1.0\ild004v2" -i"C:\Program Files\COSMIC\FSE_Compilers\CXSTM8\Hstm8" -clDebug\ -coDebug\ stm8_interrupt_vector.c
stm8_interrupt_vector.c:
Compiling sc_protec.c...
cxstm8 +modsl0 +debug -pxp -no -pp -l -i"x:\bu_thyristor_triac_rectifier\04_ase_thyristor_triac\promotion tools\digital dimmer with viper_steval-ild004v2\05_software\steval-ild004v2 software v1.0\steval-ild004v2 software v1.0\ild004v2" -i"C:\Program Files\COSMIC\FSE_Compilers\CXSTM8\Hstm8" -clDebug\ -coDebug\ sc_protec.c
sc_protec.c:
Compiling reset.c...
cxstm8 +modsl0 +debug -pxp -no -pp -l -i"x:\bu_thyristor_triac_rectifier\04_ase_thyristor_triac\promotion tools\digital dimmer with viper_steval-ild004v2\05_software\steval-ild004v2 software v1.0\steval-ild004v2 software v1.0\ild004v2" -i"C:\Program Files\COSMIC\FSE_Compilers\CXSTM8\Hstm8" -clDebug\ -coDebug\ reset.c
reset.c:
Compiling pb_reading.c...
cxstm8 +modsl0 +debug -pxp -no -pp -l -i"x:\bu_thyristor_triac_rectifier\04_ase_thyristor_triac\promotion tools\digital dimmer with viper_steval-ild004v2\05_software\steval-ild004v2 software v1.0\steval-ild004v2 software v1.0\ild004v2" -i"C:\Program Files\COSMIC\FSE_Compilers\CXSTM8\Hstm8" -clDebug\ -coDebug\ pb_reading.c
pb_reading.c:
Compiling main.c...
cxstm8 +modsl0 +debug -pxp -no -pp -l -i"x:\bu_thyristor_triac_rectifier\04_ase_thyristor_triac\promotion tools\digital dimmer with viper_steval-ild004v2\05_software\steval-ild004v2 software v1.0\steval-ild004v2 software v1.0\ild004v2" -i"C:\Program Files\COSMIC\FSE_Compilers\CXSTM8\Hstm8" -clDebug\ -coDebug\ main.c
main.c:
Compiling halt_mode.c...
cxstm8 +modsl0 +debug -pxp -no -pp -l -i"x:\bu_thyristor_triac_rectifier\04_ase_thyristor_triac\promotion tools\digital dimmer with viper_steval-ild004v2\05_software\steval-ild004v2 software v1.0\steval-ild004v2 software v1.0\ild004v2" -i"C:\Program Files\COSMIC\FSE_Compilers\CXSTM8\Hstm8" -clDebug\ -coDebug\ halt_mode.c
halt_mode.c:
Compiling gpio_config.c...
cxstm8 +modsl0 +debug -pxp -no -pp -l -i"x:\bu_thyristor_triac_rectifier\04_ase_thyristor_triac\promotion tools\digital dimmer with viper_steval-ild004v2\05_software\steval-ild004v2 software v1.0\steval-ild004v2 software v1.0\ild004v2" -i"C:\Program Files\COSMIC\FSE_Compilers\CXSTM8\Hstm8" -clDebug\ -coDebug\ gpio_config.c
gpio_config.c:
Compiling freq_detect.c...
cxstm8 +modsl0 +debug -pxp -no -pp -l -i"x:\bu_thyristor_triac_rectifier\04_ase_thyristor_triac\promotion tools\digital dimmer with viper_steval-ild004v2\05_software\steval-ild004v2 software v1.0\steval-ild004v2 software v1.0\ild004v2" -i"C:\Program Files\COSMIC\FSE_Compilers\CXSTM8\Hstm8" -clDebug\ -coDebug\ freq_detect.c
freq_detect.c:
Assembling smart_reset.s...
castm8 -xx +lDebug\smart_reset.ls -i"C:\Program Files\COSMIC\FSE_Compilers\CXSTM8\Hstm8" -oDebug\smart_reset.o smart_reset.s
Running Linker
clnk -l"C:\Program Files\COSMIC\FSE_Compilers\CXSTM8\Lib" -o Debug\ild004v2.sm8 -mDebug\ild004v2.map Debug\ild004v2.lkf
#error clnk Debug\ild004v2.lkf:1 segment .bss size overflow (38)
The command: "clnk -l"C:\Program Files\COSMIC\FSE_Compilers\CXSTM8\Lib" -o Debug\ild004v2.sm8 -mDebug\ild004v2.map Debug\ild004v2.lkf " has failed, the returned value is: 1
exit code=1.
ild004v2.elf - 3 error(s), 0 warning(s)
2019-04-03 10:20 PM
Code / data size overflow.
Try optimization, a better toolchain/compiler, or a MCU with more memory resources.
Reading and interpreting toolchain console output is a crucial skill - consult compile help pages and tutorials.
2019-04-04 1:01 AM
Thanks, originally working in STM8S103F2P. But when I change to bigger ram chip STM8S103F3P, already have the problem.
2019-04-04 1:18 AM
Difficult to assess without code.
I would check the map file, to see what happens, i.e. what objects() cause the problem.
".bss" is usually for non-initialized objects (variables).
This section could be declared smaller on the second MCU, even with greater RAM size.
I't s several years ago when I last did a project for a STM8 ...
