2007-08-08 2:54 AM
How to resume debugging when STR7 in power down mode?
2007-07-30 7:13 PM
As JTAG is not connecting when STR7 in power down mode,right?
So what to do to resume JATG connecting when the IC is in power down mode? especially if the IC already programmed with codes that enter power down mode when power on! then there is no time to connecting to JTAG after power on,right?2007-08-08 2:54 AM
You can simply change the boot jumper on your board and then you will be able connect to the IC and load a new code. Also, resetting the board just before connecting to the IC or loading a new code is possible. ;)We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
