Generate PWM signal+ Timer
agiddari_58
Associate II
Posted on March 10, 2009 at 09:42
2 REPLIES 2
agiddari_58
Associate II
Posted on May 17, 2011 at 09:58
Hi everybody,
I am a newbie and I am working on a STR912 development board.
I want to generate a PWM signal with a 10 pulse wave. (T1 to T10)
The wave period is constant whatever the message and the gap between 2 pulses is constant as well.
A longer pulse means the beginning of the signal which has a constant period.
Each pulse lenght is loaded depanding the message to send. (Each value is loaded from an array)
I manage to generate a PWM signal with a constant duty signal. I can not figure out how to change each pulse length independently. I think I have some difficulties with interrupts management.
Can someone please HELP !
Thanks a lot.
Jimmy
agiddari_58
Associate II
Hi everybody,
I manage to generate correctly interrupts but I still can not figure out how to generate 10 pulses with different pulse length (same gap between each pulse), this every 50ms for example.
I need to use 2 timers, one for the full period and one to generate each pulse. (signal output: pin 5 of GPIO6)
please someone can help...
regards,
Jimmy
