2004-08-30 9:40 PM
2004-08-19 10:15 AM
ST72F521/Cosmic/indart
I've developed my project with Fosc=8MHz. I'd like to increase the Focs to 16MHz,by External RC crystal. when I used the datablaze programer with ''Oscillator option type-resonator Oscillator'' in the option byte it works properly. The quetion is: How can I fix the 16MHz Fosc to work with the debugger? I'd like to use the external crystal on my target as the Fosc in debug mode, is it possible ? Thanks atz2004-08-30 9:40 PM
I think the section on ''Configuring the MCU'' in the ''inDart-STX for ST7'' manual should help you.
