2005-06-17 3:39 PM
2005-06-15 5:14 PM
I'm facing problem connecting to my emulator: The error stated is Error:Vehicle fault detected. I suspect the emulator is spoilt. Pls advise. Rgrds, Ong2005-06-15 8:15 PM
you can try to reduce the connection frequency from 8MHz to a smaller value On ''Connection control'' window right click on your connection and select ''configure device info''. -->> Select new frequency. bye smart2005-06-15 11:42 PM
What is the significance of the JTAG speed?
Rgrds, Ong2005-06-17 3:39 PM
OK.Thanks for the information. Rgrds, OngWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
