2006-09-18 4:25 AM
2006-09-18 12:20 AM
Hi. I use 10 MHz clock signal at CK pin in my application (using STR711FR2). Internally I want to set-up MCLK to 40 MHz and PCLK2 to 5 MHz. I have observed that I must insert some nop cycles after clock switching in order to run my application correctly. But why? Is there any clock stabilisation time? How long is it? Where can I find related data? Thanks a lot.
2006-09-18 4:25 AM
After adjusting the PLL, you have to wait until it's stabilized before you can use PLL output for system clock. It's described in the reference manual, section 3.4.1 - PLL1 Clock Multipier.
PLL lock time is specified where you would expect: in the datasheet, section 2.3.3 - Clock And Timing Characteristics. Make sure you have the latest version of the datasheet, dated August 2006. Regards, - mikeWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
