2007-04-26 2:33 AM
2007-04-25 7:34 PM
Just to double check : If I set Fosc in ST7V to 16MHz, Fcpu will be 8MHz (as per data sheet), is that correct? Thank you2007-04-26 2:33 AM
You are right. There is a divider by 2 on all external sources (clock or oscillator).
Best regards LaurentWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
